Community Member
Change PRI's to In-Band Call Signaling
Hello Voice Guru's,
I have an request from our server team. We have a program that when someone calls into from the PSTN and leaves a message the program will call out via our PRI's.
We have been having sporadic issues with this program and finnally got ahold of the vender and they ran a wireshark trace. According to them we are using out of Band signaling and the program works better when it uses in-band signaling.
We currently have several PRI's that terminate on an H.323 Cisco 2911 gateway running c2900-universalk9-mz.SPA.150-1.M5.bin. It seems to me that calls coming in-bound from the PSTN that I could change to in-band call signaling on the dial-peer ( I seem to rember there may be a command that can change that on the dial-peer)  but, I'm unsure how I could accomplish this on the calls going out from the server to the PSTN.
It seems to me that is the whole purpose of PRI's is that you have one channel for call signaling out of band.
Would this be possible?
Dan
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Under DP:
dtmf-relay
based on you description, method should be 'rtp-nte', that is also the most used generally.
Please remember to rate useful posts clicking on the stars below.
Dan,
Not sure what that program is but enabling MTP can help in this band conversion. Did you try that ?
GP.
Pls rate helpfuls posts !!
Re: Change PRI's to In-Band Call Signaling
There is no "in-band" calling on PRI.
You can discuss that with your wireshark expert, show them the trace on the router tha does ALL outbound calls via IDSN q.931.
Community Member
HI Paolo,
I thought PRI's natively use out-of-band for call signaling.
23 B channels for data and 1 D channel for Call Signaling.
Yes. I had mistyped my post above.
If you describe the problem with the full details and call flow, it may be better understood.
Community Member
Hello, we have five PRI's that terminate on a cisco 2911 Cisco router using H.323
We have a sigle site deployment with one CM 4.x Publisher and one Subscriber.
Below is the dial-peer that matches the extension and sends it to the server.
dial-peer voice 9992290 voip
destination-pattern 5252
session protocol sipv2
session target ipv4:10.0.0.69
session transport udp
codec g711ulaw
no vad
This extensions goes to a menu where users can play prompts via the dial pad on there phone. It is reported on certain occasions that a user presses a number on the dial pad but, the system does not recognize or go through.
I spoke with the vender that makes the software and they had said they thought we needed to change the call signaling to in-band for the DTMF tones.
It seems to me that I should be able to some how alter the dial-peer to maybe help DTMF along?
thanks,
Dan
Under DP:
dtmf-relay
Community Member
Hi Paolo,
I added in the dial-peer:
dtmf-relay rtp-nte sip-notify
As reccommended. I have not had a call back from the vendor so I'm thinking that may have helped.
Thanks for the nice rating and good luck!
460
