Change softkey layout for missed calls
When we hit directories -> Missed Calls the button layout is Dial, EditDial, Exit, more. We have to hit more in order to get to details. How can we move the details button so it's on the first softkey screen?
We are running CUCM 7.0(2)
Thanks in advance
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Greyson,
This change is not available in CUCM (any version that I know of). I've tried the same thing
myself before and just re-visited this when you posted up this question. You will see that the problem
here is that the call state of "Directories" is not available/selectable as an option to modify;
Configure Softkey Layout
The administrator can configure softkey sets for each call state for a  nonstandard softkey template. When the administrator chooses Configure  Softkey Layout from the Related Links drop-down list box on the Softkey  Template Configuration window and clicks Go, the Softkey Layout Configuration window displays.
The Softkey Layout Configuration window allows you to specify the  softkeys and their relative order for any phone models that support  downloadable softkey templates. This window lists all softkeys, even  though some phone models do not support all softkeys. To determine  whether your phone model supports a softkey, see the Cisco Unified IP Phone Phone Guide for your phone model. If you choose a softkey that is not supported by  the phone, the softkey does not display on the phone, even if you add it  to the Selected Softkeys pane.
Note Cisco  recommends that a softkey remain in the same position for each call  state. This provides the user with consistency and ease of use; for  example, the More softkey always appears in the fourth softkey position  from the left for each call state.
The Softkey Layout Configuration pane contains the following fields:
Select a call state to configure—This drop-down list box displays the  different call states of a Cisco Unified IP Phone. You cannot add,  update, or delete call states. The call state that gets chosen from the  drop-down list box indicates the softkeys that are available for that  call state. Table 42-7 lists the call states.
Table 42-7     Call States
Call State
Description
Connected
Displays when call is connected
Connected Conference
Consultation call for conference in connected call state
Connected Transfer
Consultation call for transfer in connected call state
Digits After First
Off-hook call state after user enters the first digit
Off Hook
Dial tone presented to phone
Off Hook With Feature
Off-hook call state for transfer or conference consultation call
On Hold
Call on hold
On Hook
No call exists for that phone.
Remote In Use
Another device that shares the same line uses call.
Ring In
Call received and ringing
Ring Out
Call initiated and the destination ringing
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Hi Greyson,
Call State
Description
Connected
Connected Transfer
Digits After First
Off Hook
On Hold
Call on hold
On Hook
Remote In Use
Ring In
Ring Out
Cheers!
Rob
Thanks for confirming. I was looking around for a day or so trying to figure this out. Glad I didn't miss something obvious.
Hi Greyson,
No you aren't losing it my friend You are most welcome!
Cheers!
Rob
833
