change the prompt during the two internal phone call connecting?
hi all,
is it possible to change the prompt during the two internal phone call connecting?
the  phones are all registered with the CUCM 6.1.3, and i have found the  there are so many prompt files in the tftp management menu, but when i  replace all those files and reload the tftp service or even reload the  server, it is no effect.
i do not know how can i found the prompt file to change.
thanks in advance.
1 ACCEPTED SOLUTION
If you mean you want to change the ringback tone that is not possible.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
hi,
can someone help me?
thanks in advance.
yu.
java
java
hi java,
thanks for your prompt reply, i mean the ringback tone as you said.
and i want to know that what are these .au files use for which we can find in tftp management menu. i found in the cisco website, but got nothing about that.
thanks in advance.
yu.
323
