Change to second dial-peer
I'm looking to have a call go to a second dial-peer after a set delay.
For example, I have dial-peer A and dial-peer B with the same destination-pattern.  I will put a higher preference on dial-peer A.  Call comes in and rings dial-peer A for 15 seconds.  No answer so call is redirected to dial-peer B.
Thanks in advance for any help
The preference command on the
The preference command on the dial-peers is for redundancy and when the call routes through dp A and fails, it will then route through dp B. However, in your case, the call reached the other end successfully using dp A and is now in the alerting state. Therefore, post this, even if the call is not answered, the router will not consider that to be a fail and route it out through dp B.
So unfortunately, your requirement can't be fulfilled using the preference command.
Sorry if I wasn't clear.  I
Sorry if I wasn't clear.  I knew that the preference command will not give me the result I was looking for, I was just saying I would use that to go to dp A first.  I was just hoping someone knew a way to go from an alerting state on dp A to dp B.
Ah ok. Unforunately, there
Ah ok. Unforunately, there isn't any way of achieving the move from dp A to dp B on alerting.
Not sure if TCL scripting
Not sure if TCL scripting might be able to do this, you can look into that.
java
if this helps, please rate
www.cisco.com/go/pdi
OK, thank you gentlemen for
OK, thank you gentlemen for your time.  Looks like I'm going to need to find a different solution.
46
