I have a UC560 with PRI setup at the primary site and like to setup another UC at a remote site. What's the easiest way to change the default IP address of CUCM and CUE for the remote UC?
The 2 sites are connected via MPLS. Can the remote site have a different area code number using the same ISP from primary site?
You can use either GUI or CLI to change address. Note that as always when changing address, your risk loosing connection in doing it, so better you have all planned out.
And the answer to second question, yes.
