Community Member
Changed Dialed Number displayed on phone
I have prepended access codes to my outbound pots dial peers, so that i can selectively match which port is used. The access code is now displayed on the phone, such as 391XXX-XXX-XXXX. Is there a way to change what is displayed on the phone? thx
Hall of Fame Super Gold
Re: Changed Dialed Number displayed on phone
Are you using CME or CCM, and which version ?
Community Member
CCM 4.2
i will be moving to cm7 in a few months, please comment if it is different in cm7
thanks
105
