tka
Changing Active-Directory-Synchronized CCM fields !!??
Hi all,
Is there a way to change the department of CCM users synchronized with an Active Directory ?
The question applies also to :
Middle Name
Manager ID
Department
Phone Number
Mail ID
Which are parts of the "Fields to be synchronized" in the LDAP directory Information Form.
best regards,
1 ACCEPTED SOLUTION
Re: Changing Active-Directory-Synchronized CCM fields !!??
yes, change it in AD
if you cannot change a field in CUCM is because you need to perform the changes directly in AD
no, it's not possible not to include it
java
if this helps, please rate
java
www.cisco.com/go/pdi
the information is on the SRND and when you create the integration you get to choose from fields that have 2 or more values. if there is no option you obviously cannot choose.
Table 18-4 Data Attributes Imported by Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/directry.html#wp1045145
java
java
tka
I meant that , actually, it is not possible to change the Department of a user once we have performed synchronization with an Active Directory .
Is there a way/trick to change this field although I have a Synchronization in place ? or at least, is it possible not to include the department field in the fields that are aynchronized with the Active Directory.
Hope I got more clear than the first time.
best regards,
java
java
155
