04-11-2012 01:09 PM - edited 03-16-2019 10:35 AM
How can I do this? All of the direction I find seem to use some other GUI interface and I can't seem to migrate it to CCP.
04-11-2012 02:40 PM
04-11-2012 06:19 PM
Have you followed the following directions?
did you stop and start the TFTP service?
04-11-2012 08:11 PM
I just reloaded the router.. Many times.. like I said, when running the debug I see the phone look for the list.xml file, find it and read it but nothing else happens. The .png images are in the appropriate folder and from what I can tell are the correct size and format. I didn't think the phone was accessing the files but the debug proved that they were. Atleast the list.xml file. I will look at the above directions but I've looked at countless directions all day and just don't see what I am missing anymore.
Thanks for the response!
04-12-2012 07:22 AM
I figured it out. My .xml file was really jacked up for some reason. I re-created it and all is fine. Apparently Word XML changed some formating.
