Changing CAS e&m-wink-start to a PRI on voice gateway
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
I want to change a CAS  e&m-wink-start to a PRI on controller T1 0/1/0 using mgcp below. I am posting the new configuration below the current e&m-wink-start configuration on the voice gateway router.
Current
controller T1 0/1/0
cablelength long 0db
ds0-group 1 timeslots 1-24 type e&m-wink-start
description
New configuration
Router(config)# no contoller T1 0/1/0
Router(config)# no interface Serial0/1/0
Router(config)#controller t1 0/1/0
Router(config-controller)#cablelength long 0db
Router(config-controller)#framing esf
Router(config-controller)#linecode b8zs
Router(config-controller)#clock source line
Router(config-controller)#pri-group timeslots 1-24 service mgcp
Router(config-controller)#description circuit ID
Router(config-if)# interface serial0/1/0
Router(config-if)# no ip address
Router(config-if)# encapsulation hdlc
Router(config-if)# isdn switch-type primary-4ess
Router(config-if)# isdn incoming-voice voice
Router(config-if)# isdn bind-l3 ccm-manager
1 REPLY
VIP Super Bronze
Re: Changing CAS e&m-wink-start to a PRI on voice gateway
You need additional configs for this to work..You also need to configure the isdn bind on the D-channel not as you have it..
Router(config-if)# interface serial0/1/0:23
Additional configs....change ip to suit your needs
ccm-manager redundant-host 192.168.103.114
ccm-manager mgcp
ccm-manager music-on-hold bind xxx--put relevant interface
mgcp
mgcp call-agent 192.168.103.115 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp modem passthrough voip redundancy
mgcp ip qos dscp af31 media
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package dtmf-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
mgcp tse payload 100
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interfacexx -----------------------put relevant interfcae here
mgcp bind media source-interface xxx--------------------same
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
344
