Community Member
Changing CLID of PRI
Is it possible to change the Caller Line ID of an Individual PRI connected to AS5400 VG in the IPCC Enterprise Environment.
Hall of Fame Super Gold
Re: Changing CLID of PRI
Within the limits of what your telco allows, yes.
Community Member
Hi Bevilacqua,
I am able to make it by setting the External phone number mask in the IP Phone and checking the calling party external phone number in route pattern.
Could you please brief me how i can acheive this in the AS5400 VG.
Gopi
Anonymous
N/A
Hey I could use an example of your inbound dial-peer config on that (if you have DID's"
I am working on getting inbound calling set up and its just not happening.
Cause i = 0x8081 - Unallocated/unassigned number
first of all check on the VG which number is sent with "debug isdn q931" and "term mon".
Community Member
In my case i would like to know how to change the outgoing calling party number.we have 2 pri under a trunk group associated to Route pattern 9.8!#
Currently,debug q931 shows only the 5 digit Directory number of IP phone. I want to change 5 digit DN to CLID.
Configuration:
Route patern 9.8! & 9.8!# with predot Trailing -#.
VG Configuration
voice translation-rule 4
rule 1 /^8/ //
voice translation-profile XXXX_Outgoing
translate called 4
dial-peer voice 53 pots
trunkgroup XXXX_Out
translation-profile outgoing XXXX_outgoing
destination-pattern 8T
no digit-strip
forward-digits all
Gopi
You have to ask your telco how many digits to send. Usually that is the same as DID digits received.
Unrelated, you can remove the voice translation-profile, rule, "no digit-strip" and "forward-digits all". It is not necessary because a pots DP already strips matched digits in destination-pattern.
Community Member
clid command under dial-peer voice enabled me to change the network calling number.
Gopi
229
