Changing CUCM 7 Administration Web Page Language
Hi all,
i'm facing a difficult time on trying to change the WEb administration page language.
My cucm is running with some kind of translation on the web page. Some itens are translated to portuguese (my native language) and other itens are in english.
I want to put everything in english.
Any clue on that?
thanks
1 ACCEPTED SOLUTION
Re: Changing CUCM 7 Administration Web Page Language
Make sure the language selection for your browser is set to English as 1st option.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Thanks Man....worked like a charm
Hello All,
My problem was solved too. Thans.
I had the same problem.
It Was Solved too.
Thanks.
960
