Changing CUCM server capacity on UCS
If I have a CUCM 8.6 cluster on UCS that was built using the 2,500 user OVA template is it possible to change the server capacity/processing power to that of a server built using the 7,500 user OVA template by just modifying the vCPU, memory and disk space using the vSphere client or would I need to back it up using DRS, build a new server with the 7,500 user template, then do a restore?
Everyone's tags (1)
1 ACCEPTED SOLUTION
CPU & Memory are easy to change. The problem's always been disc size. But I've just discovered this on support.cisco.com:
http://www.cisco.com/web/software/282204704/18582/ciscocm.vmware_disk_size_reallocation_v1.0.pdf
GTG
Please rate all helpful posts.
GTG
Hall of Fame Super Silver
I belive this will only work and be supported with CUCM 10.0 and on.  For previous versions the only solution is still to backup with DRS, deploy new OVA and install CUCM and restore from the DRS.
HTH,
Chris
Chris,
I am not sure your assessment is accurate. I looked through the document and my understanding is that Cisco is providing a COP to allow users to expand the disk space for UCM 9.1 and earlier.
-Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
I guess I should have read the doc :-)
For some reason I remembered this being discussed as a new add-on to version 10, things must have changed.
+5 for correcting me Bill, +5 Gordon for nice find.
HTH,
Chris
Your memory is fine. I recall the same statement being made at some partner session. I guess someone, somewhere realized that this should be retrofitted to all versions. Good choice on Cisco's part.
-Bill
Thanks all - great info
257
