Community Member
Changing CUCM Tomcat default ports
Do you know if it's possible to change CUCM Tomcat tcp ports 8443 and 8080 to other values ?
I've checked into Enterprise parameters but I've seen nothing.
1 REPLY
Not possible
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
259
