Community Member
Changing displayed dialed number on the phone
I have a route pattern 9.XXXXXXXXXX that points to a route-list.
In the route-list, I have the following two route-groups pointing to the same CUBE:
- RG #1 Predot
- RG #2 Predot + Prefix 999 (used to do some OTG header manipulation in the CUBE)
I don't want users to see on their phones the 999 in front of their dialed number if the call gets routed to the 2nd route group.
I also don't want to set option "Always Display Original Dialed Number" to yes since it will break other things in our setup.
Is there a way to do this?
I'm using CUCM 8.5
-Simon
Everyone's tags (1)
1 REPLY
hi,
Use calling Party transformation for this at the
Route list or route pattern level.
Please find the details with the examples in the
doc below...
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a87124.shtml#rlpage
Hope this helps!
Karthik
433
