02-10-2014 05:21 AM - edited 03-16-2019 09:40 PM
I am running CUCM 9 cluster and need to change the DNS server ip addresses configured on each server. Is it just a matter of chaning the ip addresses on the cli
set network dns {primary | secondary} ip-address
and then rebooting the cluster? Do i need to rehost the License files in ELM or should the current license files work?
Derek
Solved! Go to Solution.
02-10-2014 05:30 AM
02-10-2014 05:33 AM
Hi Derek,
Just a small note to add to my friend Aman's good tips (+5)
This query did come up recently and you won't have to re-host
but there are some related ELM steps to consider
https://supportforums.cisco.com/message/4069040#4069040
Cheers!
Rob
02-10-2014 05:30 AM
Hi Derek,
No.
Licenses remain same.
regds,
aman
02-10-2014 05:33 AM
Hi Derek,
Cheers!
Rob
02-10-2014 05:56 AM
Thanks Guys. I will follow this procedure
02-10-2014 06:34 AM
Hi Derek,
thanks for ratings.
Hi Rob,
[+5] thanks for supporting.
regds,
aman
