Community Member
Changing DNS server addrresses on CUCM 9 cluster
I am running CUCM 9 cluster and need to change the DNS server ip addresses configured on each server. Is it just a matter of chaning the ip addresses on the cli
set network dns {primary | secondary} ip-address
and then rebooting the cluster? Do i need to rehost the License files in ELM or should the current license files work?
Derek
2 ACCEPTED SOLUTIONS
Purple
Hi Derek,
No.
Licenses remain same.
regds,
aman
Hall of Fame Super Red
Hi Derek,
Just a small note to add to my friend Aman's good tips (+5)
This query did come up recently and you won't have to re-host
but there are some related ELM steps to consider
https://supportforums.cisco.com/message/4069040#4069040
Cheers!
Rob
Purple
Hi Derek,
No.
regds,
aman
Hi Derek,
Cheers!
Rob
Community Member
Thanks Guys. I will follow this procedure
Purple
Hi Derek,
thanks for ratings.
Hi Rob,
[+5]  thanks for supporting.
regds,
aman
3055
