ā06-27-2012 08:59 AM - edited ā03-16-2019 11:53 AM
I have to change the DNS entries in the OS Admin portion of CUCM 8.5.1 I changed them in CUCM admin but whats the process for OS admin (attached)
ā06-27-2012 09:33 AM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_5_1/cli_ref_851.html#wp39980
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā06-27-2012 09:39 AM
Does this change cause an outage to CUCM ?
ā06-27-2012 09:42 AM
From the link
Note If you change the IP address for the primary DNS server, you must also restart the Cisco Tomcat service. For more information, see the utils service command.
java
ā06-27-2012 10:03 AM
Restarting Tomcat doesn't cause an outage for core call processing functionality, only ancillary features such as extension mobility, webdialer, etc. Also don't forget that changing DNS will cause the Licensing MAC to change. You'll need to rehost the license.
Please remember to rate helpful responses and identify helpful or correct answers.
ā06-27-2012 12:11 PM
Note that if you change the DNS Domain, this will cause an immediate reboot of the server.
GTG
