Community Member
changing domain name
I need to change the domain name of my servers within the cluster. I've read a few threads that explain the proceedure for changing hostname and ip address. But with regard to domain name, can I just change this via the cli
> set network domain
and do I need to do in any particular order, i.e. pub then subs?
ta
Grant
Re: changing domain name
Hi!
As far as I know, the domain command is strictly for DNS and this will affect only DNS resolution. You can change the domain name and reboot the servers afterwards, first do the PUB and then the SUBs.
Hope this helps!
Regards, Tere. If you find this post helpful, please rate! :)
Community Member
thanks, i've alreday done it and worked fine.
188
