08-10-2009 10:58 PM - edited 03-15-2019 07:17 PM
We are running the following:
CUCM 6.1.3.2000-3
Locale (German) 6.1.3.1100-1
7945/7965 Firmware SCCP45.8-5-2S
My question is about the Font size on the 7945/7965 phones (menu, softkeys etc). In earlier versions of this system (e.g. CUCM 6.1.1.2000-3) the font was quite small and looked great. After an upgrade of CUCM (which also upgrades phone firmware) and the german locale, the font size increased quite a bit (same size as the english locale font). I could personally live with this, but our customer dislikes the large font.
What does the font size depend on, and is there a way to change it back to a smaller size without any downgrades?
Any comments would be appreciated!
Ingo
Solved! Go to Solution.
08-11-2009 07:31 AM
Usually, I do not use verbiage leading to doubt, I may have forgot my good habit for a time. So, here's your answer:
You cannot change font size on cisco phones.
No proving link can be given, because the feature never existed.
08-11-2009 01:59 AM
I don't think you can change that, to prove you point you would need to show pictures to cisco, but do not expect they actually do anything.
08-11-2009 06:28 AM
Why a "2" to my 100% true and correct information ?
Maybe you wanted to hear that is possible to change font size, unfortunately that is not possible.
It is not fair to vent your frustration to me.
08-11-2009 07:22 AM
Hi, I am not venting my frustration at you.
Your post said "I don't think you can change that". To me this does not indicate 100% true and correct information.
If you would have told me that I can definately not change the font size (and maybe provide me with a link from cisco for reference) I would have given a 5.
Thanks for your time nonetheless
08-11-2009 07:31 AM
