Community Member
changing host name to ip address
Hi, i've built a cluster and choose to use hostnames rather than ip addresses for the servers. However this had led to a lot of problems when trying to get phones to register. I'm considering changing away from host names to ip addresses, and have read through the cisco doc for changing ip address and host names on 6.x servers. One question just to be clear however:
there isn't a section in this which relates directly to changing from hostnames to ip addresses, should I be ok to just follow the instructions for changing hostnames, missing out the relevant dns parts?
ta
Grant
Community Member
Re: changing host name to ip address
I have done that in the past without any problems. As long as you follow the document correctly, you should be fine.
guess you mean only the change on the CUCM server and CUCM group, if so it's only necessary to change those entries, restart the TFTP service to recreate the files and reset all phones so they get the change
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
thanks for the help guys, worked fine
294
