Community Member
changing IP address on server
if our company is going to do some IP addresses and IP class address changes. Are there any things I should consider when changing the IP address of the Unity server, Call Manager 4.x? Is stuff going to break?
Re: changing IP address on server
Unless you following the documented steps, then yes you will certainly run into problems:-
Changing CallManager IP Address:-
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094601.shtml
Changing Unity IP Address:-
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_090.html
Hope this helps.
Allan.
Please rate helpful posts.
Community Member
Thanks for your help. Very informative.
141
