01-19-2007 02:57 PM - edited 03-14-2019 07:38 PM
I need to change the name of a server with Callmanager installed on it, what is the impact of doing that change on everything, Windows, Calmanager aplication, SQL, etc?
Solved! Go to Solution.
01-19-2007 03:35 PM
You cannot change name of Callmanager server after callmanager is installed. This is due to SQL limitation. You will have to reinstall it if you change the name of the server.
HTh
sankar.
01-19-2007 03:35 PM
HTh
sankar.
01-19-2007 03:54 PM
Thanks, I was afraid to hear that.
01-19-2007 04:09 PM
One question - are we talking about changing the CallManager Name (in CallManager itself), or changing the computer name in Windows?
Or Both?
01-19-2007 04:12 PM
Changing Windows computer name. This is not supported
