Changing NTP server 5.13
I need to change NTP servers on my CCM5.13 install and cannot find where to do it. Anyone know off hand?
Thanks Ahead
Todd
1 REPLY
Re: Changing NTP server 5.13
Step 1 From the Cisco Unified Communications Operating System Administration window, navigate to Settings>NTP Servers.
The NTP Server Settings window displays.
Step 2 You can add, delete, or modify an NTP server:
-To delete an NTP server, check the check box in front of the appropriate server and click Delete.
-To add an NTP server, click Add, enter the hostname or IP address, and then click Save.
-To modify an NTP server, click the IP address, modify the hostname or IP address, and then click Save.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/5_0_4/iptpch4.html#wp1042131
115
