Community Member
Changing password
I have just acquired the responsibility of our office phone system. We have a new employee starting work on Monday, and I need to be able to reset the mailbox password on (what will be) her phone.
I reset the phone (7941) to factory defaults, but I still can't get into the mailbox. What is the default password, and how should I proceed from here?
Thanks!
Everyone's tags (1)
Hall of Fame Super Red
Changing password
Hi Brittany,
You likely have some sort of voicemail "system" that controls this config.
Can you check into what system you are running...is it router based (Cisco CUE), server based
(Cisco Unity or Unity Connection)? Maybe you are using a UC500 system?
If you can provide that info I'm sure someone here can help you out
Cheers!
Rob
Community Member
Changing password
We're using Cisco Unity Express v3.1/Call Manager Express vCME 4.1.
Pretty sure we're router based.
Hope that helps. Thanks for the response.
Changing password
Hi Brittany,
The steps are shown in the Administrative tasks section of the
Administration Guide (CUE)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/administration/guide/gui/gui_admin.html
Cheers!
Rob
Community Member
Changing password
Thank you.
I tried that once before, but mistakenly changed "password" instead of "pin."
Everything is taken care of now. Thanks again for the help.
Changing password
Hi Brittany,
You are most welcome Good work!
Cheers!
Rob
248
