Community Member
Changing PhoneGuides for CCMUSER
If a User opens his personal device configuration over IP Adress of CUCM he can download the manual or quick reference guid for his used telepone.
Because some changes about the button configuration we need to use another adjusted version of the manuals and update the link for the guide in ccmuser used.
- How can I upload new documents (pdf) to the PhoneGuides path which is used in the link in ccmuser?
- Where can I change the link for used manual in ccmuser?
I hope someone can help me!
1 ACCEPTED SOLUTION
Re: Changing PhoneGuides for CCMUSER
You can't. You'll need to provide them the guides in some other way.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
no ideas?!
java
java
384
