Changing Route List "batting order"
I am cutting over to fatter pipe for my SIP PSTN trunking services which will require a downtime.
During the downtime for the voice gateway (which will hopefully be very short!) I would
like to have users at site A make calls via the voice gateway at site B.  And I want
to do this without powering down/disconnecting the voice gateway for site A.
The way I was considering was to make site B's voice gateway top of the route
list for site A.  It is currently in the second slot.  If I did this would I have to
reboot the phones or take other action to affect the change in routing preference?
Alternatively I could go to the site A route group and replace the Site A voice
gateway with Site B gateway.  Or just add Site B gateway and make it top of
the list.
Would one method be better (ie least effort, least intrusive) than the other?
I normally never touch the route lists and groups but need to plan for the
moment to moment change process for the cut-over.  Thank you.
1 ACCEPTED SOLUTION
Green
Re: Changing Route List "batting order"
Your 1st option looks good
Promote the B gateway to be the 1st choice.
Save and reset list if you are asked too.
Outage will be about 1-3 seconds and will only affect new outbound calls
Alex
Regards, Alex. Please rate useful posts.
Green
Alex
Thank you!
206
