Changing specific parameter using BAT
Currently all phones have a main number as their external mask. How would I go about changing the external phone number mask to their own individual number.
I thought i could just edit a .csv file with MAC ADDRESS, DIRECTORY NUMBER, and EXTERNAL PHONE NUMBER MASK as headings and then do a phone >insert phones specific detail on BAT but this does not quite work as well because some parameters change as well when I run BAT.
I may be using the wrong BAT option. Any suggestions??
Thanks!
Marvin
1 REPLY
Re: Changing specific parameter using BAT
Hi!
What's the CUCM version you have? I will recommend to export ALL phones - All details and then modify the CSV file, with the external phone number masks and import them again.
HTH!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
147
