Changing the 7970 fonts.
Hello, is it possible to change the fonts of a specific ip phone 7970. i mean to change the color and size and not to affect all the phones.
And if not, is there any model which can do theses changes?
thanks
Hall of Fame Super Gold
Re: Changing the 7970 fonts.
I think you had asked this question already ?
Unfortunately, it is not possible to change font size or color or any other appeance element, on any cisco phone.
I wanted to add what I think is the only possibility for increasing visibility of cisco phones.
That would be some special version of the applications that run on the PC and popup when the phone rings.
However, it requires extensive programming.
Thanks for the nice rating and good luck!
thanks , well try to find out another way.
I know this isn't a direct answer to your problem but I was trying to think "outside the box" for you.
Do you have Unity?  Could a call screening option work for you?
432
