Changing the dial plan
Hi Everyone
I wanted to know is there any documentation that can help me redo our dial plan for my current job.
Right now have 5 digit extension and they want ot go to 4 for internal and 6 if you have to go outside
the office.We just purchased a company and they have there dial plan set that way and we like that
better. We want to be able to dial 4 digits for inside and 6 for outside to other offices.and the 6 will be
the first 2 are the office code and the last 4 are the user's extension.And we want to if you dial 4 or6
internally you still get the end user.So if anyone has done this before or can point me in the right direction
to get started I would greatly appreciate it.Thanks in advance for all the help and I look forward to your
answers.
Everyone's tags (4)
Hi, just wanted to confirm that all companies and all offices are registered to one CUCM in your office. Is it right?
"If you find this post useful, please rate"
Yes there are all registered to the same CM
Hall of Fame Super Silver
Your best bet you be to review the dial plan section of the SRND as there are many ways to design and deploy dial plan so you will not find step by step instructions on how to change it.
You need to re-evaluate the existing dial plans on both sides and come up with one new dial plan that will work and not introduce overlaps, etc.
Design it and then start configuring it, change DNs if you have to, Translation Patterns, etc, etc.
Chris
237
