Community Member
Changing the display of an IPT (Cisco 7940)
Can I change the display of an IPT (Cisco 7940)? I want to change it with my company logo or even cisco logo.
Community Member
Re: Changing the display of an IPT (Cisco 7940)
More importantly which version CUCM are you running.
Carlton.
Community Member
I am using CUCM version 4.2
Community Member
Search for IP services. There are a lot of samples, that can be attached to the IDLE textbox in the phone configuration on the CalManager
Community Member
You can create a .PNG file within any paint package and upload to your CUCM. From here you can apply this to your device.
Happy hunting
Carlton.
think this is what you're looking for
Creating Idle URL Using Graphics on Cisco IP Phone
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801c0764.shtml
java
if this helps, please rate
www.cisco.com/go/pdi
470
