Community Member
Changing the packet size in CME
I need to change the default packetsize on all 7906 and 7911 IP phones. Can anyone help me?
thanks in advance
Olivier
Hall of Fame Super Gold
Re: Changing the packet size in CME
Sorry, ASAIK it is not possible to do so.
Community Member
Evgen with the codec command in the dial peer ?
ie codec g729r8 40
CME doesn't use configured DP's, it uses ephone.
And the "codec g729r8" command doesn't supports bytes settings.
215
