Changing the web interface
Is there a way to change the red CISCO sign on the upper left portion of the web interface for CUCM 8.0.2?  We want to change each one to a different color.  The colors we need are green, red and grey.  Each color would be on a different network.  I know it seems dumb but we want to make sure we are using the right CUCM at a quick glance.
Jaime Valencia
No, you cannot change it.
You may add a custom message to tell you which server you're in
Setting Up a Customized Log-on Message
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_0_2/cucos/iptpch7.html#wp1054249
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
