Changing unified mobility alternate number timings in ccmuser
Hello.
I've got a problem with configuring unified mobility alternate number timings in user interface. I can configure values in milliseconds in administrative interface but in user interface these values are requested in seconds. When I trying to set 4 seconds value for delay before initiating a call to alternate number CUCM can't validate it - it awaits a value in 10000 - 300000 range. Is there a fix for this? I'm using CUCM 8.6.2.20000-2 with Russian localization.
Maxim Denisov
Everyone's tags (3)
I have the same problem. Do you still have a solution?
I believe this is fixed in newer versions but I haven't tested.
Thanks for your reply, we will upgrade to 9.1 soon, I hope it will be solved.
Mirko
Same here: CUCM 8.6(2) with German Localization:
  - This actually prevents users from disabling Mobility via CCMUser altogether!
  - If I prefer en-US as the Language within IE, this issue doesn't happen (so it's caused by some localization issue)
Looking forward to hear whether 9.1 changed anything for you guys
Cheers
/David
Turns out that CUCM 9.1(1) solved the issue for me.
652
