Changing User ID in DC Directory (CCM v8.)
Does anyone know if it's possible to change the user ID in the global directory (used to be called DC directory, not sure if it still is or not). Anyway, I've read all the posts, and in all previous versions of CCM, you couldn't do it without deleting and recreating, but those posts were quite old.  Just wondering if that's changed in CCM v8.x?
Reason I'm asking is this:  We're upgrading from CCM v4.x to CCM v8.x, and our contractor has imported all of our old style usernames.  We changed a few years back and went to a standard format (email address without the @domain.com).  Anyway, since they've imported all of our usernames, I was hoping I could somehow easily change them.
Any thoughts from the CCM crowd?
Dave
1 REPLY
Re: Changing User ID in DC Directory (CCM v8.)
Still the same limitation, you could export the user settings through BAT and then re-import them which escentially deletes and re-adds the users.  This assumes you're not using the LDAP directory integration which it sounds like you're not.
234
