Community Member
Changins Subnet Mask and Gateway for CUCM & CUC 8.6
Am planning for cutting down the Subnet of Telecom Servers IP Range. Once i do this, all CUCM & CUC servers Subnet mask and Gateway has to be changed, but IP Address remains the same.
Changing the Subnet mask and Gateway will impact anything or any precautionary measures or any procedures to be followed ??
Pls suggest.
Jagadish G
1 ACCEPTED SOLUTION
Purple
Hi Jagadish,
I was just referring the DOC which I have attached which says
Initial Trust List and Certificate Regeneration
If you change the IP address or the hostname of a server in a Cisco Unified Communications Manager release 8.0 or later cluster, the Initial Trust List (ITL) file and the certificates in the ITL are regenerated. The regenerated files do not match the files stored on the phones.
regds,
aman
Re: Changins Subnet Mask and Gateway for CUCM & CUC 8.6
Not if youre using MCS, otherwise, youll need to rehost the licenses as it affects the license MAC
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Yes we are using Cisco MCS 7800 series servers. How will the mac gets affected ??
It wont, that only affects if you are running over ESXi
java
Purple
Hi Jagadish,
you can refer the link for details
http://docwiki.cisco.com/wiki/Licensing_Model_for_Virtualized_UC_Applications
regds,
aman
Community Member
So i can go a head and change the subnet mask and default gateway without any measures right ??
Purple
Hi Jagadish,
you can do that.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_0_2/ipchange/ipchg802.html
regds,
aman
Community Member
Will the ITL files gets changed/regenerated after changing only the Subnet Mask & Gateway ??.
Purple
Hi Jagadish,
regds,
aman
252
