Cheap and Easy SIP Config
I would like to be able to configure my IP phones to make and receive calls (outside my LAN).  What is a cheap and easy way to do this?  Add a vonage device, get a SIP trunk?  Also would I need to configure my router as a gateway and install CME on it?
Right now my setup is:
WAN Modem ---> Cisco 2811 ---> Switch ---> CUCM 8.6
        --->IP Phones
Everyone's tags (2)
Vonage don't offer any SIP
Vonage don't offer any SIP service for end users like that...  if you want to play in your lab, get cheaper sip trunk.
 Look at these websites
 www.sip.us
http://www.pure-ip.com/
http://www.updata.net/
I have looked into that, but
I have looked into that, but for the config part, do I add the SIP config on my router and then add a gateway in CUCM?  Also do I need PVDM modules on the router as well?  Sorry I am a bit new to VOIP and CUCM.
 I got my SIP connection from
 I got my SIP connection from SIP.US
 Yes, you need to prepare your Router be a SIP Gateway first then connect with your CUCM.
 Personally I am using for my CME not CUCM and haven't done it before but don't think it will be different.
 Look at the below website for full SIP configuration from where you can get what you required for your own as per CUCM requirement.
http://www.adcapnet.com/blog/cisco-2800-isr-configuration-for-sip-voice-with-nat-and-firewall/
Would/Could you paste or
Would/Could you paste or email a copy of your config with sip.us?
 Having PVDM issue with that
 Having PVDM issue with that router these days so it freez but you can get from the link or from Cisco website... just google it.
146
