Community Member
check the details of active phones / calls on a callmanager
Does someone know how to see which calls or phones are active on a callmanager 5.1 ?
I know you can see the number of active calls in RTMT, but is there a way to check which calls are active ?
All feedback is appreciated.
Dirk
Bronze
Re: check the details of active phones / calls on a callmanager
Go to Programs -> Administrative tools -> Performance Monitor. Select Cisco CallManager and you'll find a number of counters there including Call Active.If you need details you'll have to pull them from CDR database afterwards
Community Member
I knew this, but I wondered if there was no way to see which calls where active ...
114
