Community Member
Checking DLU Usage in Call Manager 4.1
Does anyone know how to check the DLU usage in Call Manager 4.1. We have a site with an older Call Manager that we want to migrate the licenses and users into our 7.1 CUCM but I'm not familiar with the older version.
Thanks!
Re: Checking DLU Usage in Call Manager 4.1
The concept of DLUs does not exist on any CCM version, it only applies for CUCM.
DMA will take care of migrating the config and give you the necessary DLUs.
That, or reach licensing (licensing@cisco.com) so they can give you a spreadsheet to manually convert phones into DLUs.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hall of Fame Super Red
Hi Travis,
Just to add a link to the great info from Java
Here is the DLU Calculator;
Cheers!
Rob
947
