Choose a port to Outbound Dial Peer
Hi everyone,
I would like to know if is possible choose a port for Outbound Call based in ANI Number.
By exemple:
I have a gateway ISR with 2 ports E1
E1-1 Prefix 7000-7900
E1-2 Prefix 4000-4999
This gateways have a SIP Trunk with a Lync Server.
The Lync do a call to PSTN
Calling From 7001 to PSTN Number 21341234 -> I would that this outbound call left by E1-1 and
Calling From 4001 to PSTN Number 21341234 -> I would that this outbound call left by E1-2
I follow this DOC and the translation do not work
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
On Debug of Translte the output is
Jul 25 23:30:55.908: xrule_checking calling 4001, called +90217193952442
Jul 25 23:30:55.908: xrule_checking peer_tag 2, direction 1, protocol 3
Jul 25 23:30:55.908: h323_xrule
Jul 25 23:30:55.908: xrule_checking Return rc = -4
Jul 25 23:30:55.908: xrule_checking calling 4001, called 90217193952442
Jul 25 23:30:55.908: xrule_checking peer_tag 6, direction 2, protocol 3
Jul 25 23:30:55.908: xrule_checking Return rc = -5
dial-peer voice 4 pots
destination-pattern .....T
progress_ind setup enable 3
direct-inward-dial
port 0/0/0:0
dial-peer voice 6 pots
destination-pattern ........T
direct-inward-dial
port 0/1/0:0
dial-peer voice 100 voip
shutdown
rtp payload-type comfort-noise 13
session protocol sipv2
session target ipv4:10.145.68.5
session transport tcp
voice-class sip block 183 sdp present
dtmf-relay sip-kpml rtp-nte sip-notify
codec g711alaw
fax protocol none
ip qos dscp cs4 signaling
dial-peer voice 1 voip
translation-profile incoming 7300
answer-address 7496
codec g711alaw
fax protocol none
dial-peer voice 2 voip
translation-profile incoming 4000
answer-address 4001
codec g711alaw
fax protocol none
dial-peer voice 3299 pots
destination-pattern 3299T
port 0/0/0:0
dial-peer voice 2134 pots
destination-pattern 2134T
port 0/1/0:0
answer-address 7496
answer-address 4001
voice translation-profile 7300
translate called 1
voice translation-profile 4000
translate called 2
voice translation-rule 1
rule 1 /^9/  /3299/
voice translation-rule 2
rule 1 /^9/ /2134/
port 0/0/0:0
port 0/1/0:0
Everyone's tags (4)
Hall of Fame Super Gold
Have the other system prefix steering digits to called number.
Hi Paolo,
Thanks by reply!
What can I delete?
Im learn dial-peer still.. sorry
Silver
What Paola is saying is that Lync should do a little more.
When extension 4001 whats to make an external call, lync should prefix this with '11' for example
And when extension 7001 makes an external call, lync should prefix this with '12' (again example)
On the ISR you make two dial-peers; one for 11T and one for 12T
The dial peer 11T point to the  first E1, and 12T to the second.
JH
Understand j.huizinga
But lync can not do it ...
Change the Called number based on Calling number
It should be manipulated in the ISR
This is possible ?
Silver
Don't know Lync that well, but my colleague knows Lync very well and he has done that.
Problably two voice policies and apply this to the correct users
JH
yeah dear..
But we have 1000 users and is needed create a policy call to separate these users based your number....
I'm looking for a way to make it easier on the gw.
Silver
Then play with answer address, might work
JH
Cool...
Can you give me a light ?
Im with this problem of thread
Silver
two pots dial-peers each to a E1 line and with the same destination.
dial-peer voice 1 pots
answer-address 4...
destination-pattern
port 0/0/0
dial-peer voice 2 pots
answer-address 7...
destination-pattern
port 0/0/1
Don't know if this works, normally I make these decisions on Callmanager, or in your case Lync
JH
JH dont work :/
The call always left by one dial-peer
Re: Choose a port to Outbound Dial Peer
Dear
Lacked a configuration highlighted below and the Lync sent + before 9. Solved send 9 without + and all work like expected!
translate-outgoing called 1
port 0/0/0:0
translate-outgoing called 2
port 0/1/0:0
390
