Choosing different ports in H.323 gateway
Hi All,
Need to configure two different outgoing dial peers for two different PSTN in same gateway as one port support one DID range and another port on gateway support another DID range.
For example when  a calling number 7xxxx calls it should go the port which support 7xxxx DID range rather the next port in the gateway.
In same way when a a calling number 6xxxx calls it should go the port which supports 6xxxx DID range rather 7xxxxx.
Is it possible to configure on H.323 gateway which allow to route specific one series of extensions only take  port 0/0/0 but not 0/0/1
Port 0/0/0 >>> 6xxxx DID range
port 0/0/1 >>> 7xxxx DID range
Please help me with the configuration
SAIF
Hall of Fame Super Silver
Define your dial-peers to
Define your dial-peers to match based on "answer-address":
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
Chris
Hi.Another option to what
Hi.
Another option to what Chris suggested (+5 Chris), is to duplicate route patterns and placing them within different partitions.
To those route patterns, you can than apply an outgoing prefix that you can strip when configuring dial-peers on VG.
Eg.
RP 9.! Partition_A , put Partition_A in a CSS_A that you will assign to users that you want to let their calls through port 0/0/0
Apply outgoing prefix 123
RP 9.! Partition_B  , put Partition_B in a CSS_B that you will assign to users that you want to let their calls through port 0/0/1
Apply outgoing prefix 321
On VG
dial-peer voice 10 pots
destination-pattern 1239T
port 0/0/0:15
dial-peer voice 20 pots
destination-pattern 3219T
port 0/0/1:15
In this case VG will strip 123 prefix, for dial-peer 10 and 321 for dial-peer 20, and 9 access code.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi You can use cor list to
You can use cor list to your advantage. Some thing like below should work for you
dial-peer cor custom
 name 6xxx
 name 7xxx
dial-peer cor list 6xxx
 member 6xxx
dial-peer cor list 7xxx
 member 7xxx
dial-peer voice 10 voip
 corlist incoming 6xxx
 answer-address 6...
dial-peer voice 11 voip
 corlist incoming 7xxx
 answer-address 7...
dial-peer voice 1 pots
 corlist outgoing 6xxx
 destination-pattern .T
 port 0/0/0
dial-peer voice 2 pots
 corlist outgoing 7xxx
 port 0/0/1
Aditya
72
