Choosing rthe right ISR
I'm preparing to increase the size of our VoIP network and am aware of the principle differences between the ISRs. Our remote sites will have subscribers, so SRST is not really an issue, and the ISRs are only being used to terminate PRIs and will not be used to route data traffic. This being the case, are there caveats to using 2811 routers with 8 VWIC ports? I don't really know what to expect by way of offnet traffic, but have had success with the 2811 line and am wondering if I can repurpose for the new network and not have too much to worry about.
Also, I am planning on configuring some hardware conferencing but I have no idea yet how popular it will be.
Hall of Fame Super Gold
Re: Choosing rthe right ISR
If you need to terminate 8 PRI or more, consider AS5400HPX rather than ISR routers, that are general purpose boxes after all.
P,
This device supports MGCP (good), am wondering how this gateway is added to CUCM, I don't seem to see a model type for AS5400HPX when I go to add the gateway.
Use AS5400, CUCM won't know the difference.
Where is it? I don't see it in the list of gateways. Using CUCM 6.0, do I need a device pack update?
Sorry, not sure.
If you want safe results, use H.323 instead.
CUCM does not support the AS5400 for MGCP. The supported box is the VGD-1T3, and will do transcoding / conferencing / media termination with CUCM.
-nick
144
