Community Member
CIA on IP Phone 7912
Hi guys,
In some ip phones 7912 sometimes it shows 'CIA' instead of 'Your current optinos' in the display then the ip phone doesn?t show Missed calls and New voice mails.
Can one help me with this issue?
Thanks in advance
Hall of Fame Super Gold
Re: CIA on IP Phone 7912
Maybe these are running older firmware. A good chance to have them upgraded to latest.
Gold
Incase you are using CallManager, check the dictionary*.xml files under C:\Program Files\Cisco\TFTPPath\English_UnitedStates for this word. "Your Current Options" should be defined with number 119, dont remember the exact line and dont have access to a CallManager at this time to give you the exact names.
Basically with CM, this info is stored in the dictionary files and then pushed to IP Phones. I did some testing recently and could not find this working with 7.x and above loads with CallManager. So, upgrading the firmware might also fix this for you. But the right fix if to correct the dictionary files to show "Your Current Options" instead of CIA
Hope that helps.
139
