Cicso CP-8941 SIP
I need connect Cisco CP-8941 to Asterisk SIP server. How Can I do it? Have you got some example or howto?
  • IP Telephony
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Are you looking for a working
Are you looking for a working SEPmacaddress.cnf.xml file?  If you are, then try THIS.
If you're using UDP transport
If you're using UDP transport, what is the XML value for <transportLayerProtocol>?
Before we start, you need to
Before we start, you need to answer the most important question:  Has your Asterisk server properly authenticated with your voice service provider (VSP) yet?
Yes. I have Asterisk PBX with
Yes. I have Asterisk PBX with 80 ip phones, I have only one Cisco CP-8941, that I nedd to connect.
I was setup, phone log: file
I was setup, phone log: file ITLFile.flv failed
That file is not important.
How can I edit SEPmacaddress
How can I edit SEPmacaddress.cnf.xml file, what is important to connect to asterisk.. Firmware of phone: SIP 9-3-4-17
You can use any text editor.  I like to use Notepad++ so you'll know which XML tags are left "open".
When you edit this file, search for an XML tag called <loadinfo>.  Use the same version as stated there.
Not works. Please, do you
Not works. Please, do you able send me config file for this phone to SIP account:
username: 501
passwd:SipTestCisco
SIP asterisk server: 192.168.106.3
Thank you very much.
What troubleshooting have you
What troubleshooting have you done???
What is your settings on your Asterisk server?
Are you using TCP transport or UDP?
What firmware are you using?
Did you enable TFTP so the phone can download the SEPmacaddress.xml.cnf file?
402
