CID Questions
I'm having a hard time wrapping my head around a topic that has become a hot button issue. I need to be able to push CID to the PSTN. This wiki page explains what changes to make on call manager(4.x), but it says nothing about gateways:
http://supportwiki.cisco.com/ViewWiki/index.php/How_to_change_the_caller_ID_display_from_one_number_to_another_and_the_external_phone_number_mask_is_configured_but_does_not_work_properly
I have followed the instructions, but outbound calls are still being displayed as the telco designated CID. Is there something on the gateways(1760V, 1821) that I need to be configuring to make this possible? Beyond that, do I have to tell our telco to configure our 2 PRIs in any particular way to allow this as well? Thanks in advance for any imparted wisdom!
Re: CID Questions
get into the GW and run a debug isdn q931 or a debug voip ccapi inout.
look in the setup message what is you're sending in calling party. if it's correct and what you configured in CCM. call telco, they're overriding and you cannot fix that. telco will have to make changes
if it's the telco CID what you see in the debug then the issue is probably misconfiguration
my bet is on telco issue =)
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: CID Questions
Java,
Thanks for the response. I know next to nothing about PRI provisioning, so maybe you can answer this to me. Does the PRI, as it relates to CID, get configured to either allow us to push our own CID or override; or in other words, is a PRI only ever going to be configured one of those two ways?
Re: CID Questions
if you're using MGCP, GW has no word on CLID or ANI. whatever CUCM sends it just relays to telco. so if get's overwritten it's someone else and in all probability telco.
if using H323 then you can modify CLID and ANI using translation-rules on dial-peer and that overrides CCM info. but telco can override this.
but none of the config you can do on the GW for the PRI is to activate/deactivate overriding the CLID/ANI. that is telco's side config.
but yes, either they override the IEs or they simply pass them as you delivered them. in this case you need them to simply relay the info and not change anything.
give them a call and ask them if they're changing the ANI to what you've seen in the calls. if they're doing that, tell them you want to send your own ANI and not to modify it
java
java
Re: CID Questions
Jamie in CUCM where do you set the Caller ID?  Lets assume that the system is sending the main telephone number for your facility as the Caller ID.  You want to send your DID number as the Caller ID.  I assume you set this up in CUCM not in the Gateway?
Peter Buswell (aka DrVoIP) http://blog.drvoip.com
CID Questions
I have answered this question some minutes ago: https://supportforums.cisco.com/thread/2198196?tstart=0
For CUCM:
You need to check the "Use external phone number mask" checkbox on the Route Patterns.
Use Calling Party's External Phone Number Mask
Check the check box if you want the full, external phone number to be   used for calling line identification (CLID) on outgoing calls. You may   also configure an External Phone Number Mask on all phone devices.
Note The   calling party transformation settings that are assigned to the route   groups in a route list override any calling party transformation   settings that are assigned to a route pattern that is associated with   that route list.
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
210
