Community Member
CIMC web access
Hey team,
I´m be able to ping CIMC, but the web access does not work.
can you help me please?
Thanks.
Community Member
CIMC web access
Can you give us more information ?
is this a new configuration ? have you tried multiple web browsers ?
Community Member
CIMC web access
Yes,
It is a new configuration..
UCS C220 M3
CIMC version 1.4 (7a)
I´ve tried in differents web browsers but it haven´t worked...
I´m be to ping the Ip address, but the web access is my problem.
Community Member
Re: CIMC web access
Hi Jean
I think I may be able to suggest a solution.  I had the identical issue for CIMC on four different UCS C210 M2 servers.  If I power cycled the UCS, CIMC would resume normal operation, but the workaround only lasted for a limited time.
I asked my partner to upgrade the CIMCs.  We are at versions 1.4(3k) & 1.4(3j) and no longer experience the issue at all.  This was a permanent solution for me, but I am concerned that your version appears higher than mine.
Lastly, I also found a method online to SSH into the CIMC and restart the web GUI which helped when I had the issue: (unfortunately I am not able to credit the original source, sorry)
Now assuming you have SSH enabled, you can use an SSH client such as PUTTY to SSH over, log in, and execute:
scope cimc
reboot
The session would look something like this:
login as: admin
admin@172.16.17.3's password:
sucs-c2xx# scope cimc
ucs-c2xx /cimc # reboot
This operation will reboot the CIMC.
Continue?[y|N]
It doesn't appear to impact or interfere with any applications or VMs which may be hosted on the UCS.
Tony
Re: CIMC web access
Jean,
Can you log into the CIMC via SSH and perform a "show http"
Yosh
HTH Regards, Yosh
Community Member
Re: CIMC web access
Hey!!!
The problem has been solved... network conectivity..
thanks for help;
260
