CIMC - wrong password
Hi guys!!
I have a UCS C220 working properly, but would like to access in CIMC interface and I don´t have the corret user and password. What is the best way to reset that?
regards,
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
This doc shows the procedure
This doc shows the procedure:
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-c200-m1-high-density-rack-mount-server/111455-setup-cimc-c-series.html
F8 to configure/view CIMC IP
While in BIOS you can press F8 for the CIMC IP address configuration and password reset.
Chris
HiYou will need to hook a
You will need to hook a monitor and keyboard to the server to reset the CIMC password.
Reboot the server and you should see a message on the screen to press "f8" to enter the CIMC setup. From there you can reset the CIMC password.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks guys, I wouldn´t like
Thanks guys,
I wouldn´t like to reboot the server...
If I perform the procedure below?  What do you think about?
Procedure
 Command or ActionPurpose
Step 1Server# scope cimcEnters the CIMC command mode.
Step 2Server /cimc # factory-defaultAfter a prompt to confirm, the CIMC resets to factory defaults.
This is not going to work as
This is not going to work as you will need to enter the credentials to get to this mode. F8 is the only way if you need to reset password.
Chris
Chris
255
