CIPC 8.6.3 with free-form device name & SRST
Hi expert,
I've CIPC with free-form device name configured and registered to CUCM 8.6. Would like to know which device mac the CIPC use when it fallback to SRST? The VG configured with CME-SRST, and the provision method is auto none.
Hall of Fame Super Silver
A very good question, I guess I never bothered to test it, but I dont see how it could register with any other name but what it is configured with in CUCM, so it should be the free-form name. The question is if that is also supported on CME as SRST. I would suggest a quick test.
HTH,
Chris
Re: CIPC 8.6.3 with free-form device name & SRST
For CUCM - as chris pointed device name should be same at cucm and cipc level , then only it can register.
CME-SRST - CIPC can register with device name "free-form" only if you didn't mentioned mac-address under ephone and also enabled auto registration under telephony service.
If you see ephone summary you will se device name in mac id.
Please rate all the helpful post.
175
