Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CIPC and CME
Hi All,
     Can any one clarify to me how to make CIPC connected to Cisco Router VSEC model ,the WAN connection will be through HWIC ADSL with fixed real IP , i want a brief configuraion and explanation , which ip to make  source-address is it must to use VPN connection
Hall of Fame Super Gold
Re: CIPC and CME
With a properly configured VPN you leave ip source as the LAN one.
Note if you are the end user without the requires experience and qualification, the best choice is that you engage a reputable consultant or UC certfied Cisco partner for the configuration.
Re: CIPC and CME
Hi Paolo
Thanks for your help and support
i am R&S guy but i have basic knowlege of CCNA Voice and i am already configure CME before but GNS3 not real one so i want to check of some staff that want to be sure of them
i have another inquery does VSEC model support third party SIP Phone registeration if i decide to use third party SIP phones instead of Cisco IP phones that support SCCP , i guess yes but i need to confirm this ??
VIP Super Bronze
CIPC and CME
Yes but be advised that SIP endpoints are an entirely different configuration from SCCP. Mr. Bell has typically excellent write-up of getting a third-party SIP device to register.
http://www.netcraftsmen.net/blogs/entry/sip-endpoints-in-cisco-communications-manager-call-manager-express-x-lite.html
Please remember to rate helpful responses and identify helpful or correct answers.
CIPC and CME
Hi Jonathan,
     thanks, man. Really appreciate your input , very good refer.
221
