CIPC / CCME Question
Does anyone specifically know whether there is a firmware parameter required for CIPC ("load" command) when running it with CCME?
I have doen a fair bit of digging and all I can see so far is that you can specify the phone type as "type cipc".
I understand that CIPC is basicaly an emulation of 7970, so isn't the 7970 load appropriate?
Chris
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CIPC / CCME Question
Hi Chris,
I have not setup CIPC with CME but according to the attached doc no firmware is required. Have a look;
Cisco IP Communicator 2.0
**No firmware required**
Cisco IP Communicator 2.0 is supported by Cisco CallManager Express 3.3 using Cisco IOS Software Release 12.4.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00805f6cb4.html
Cisco IP Communicator Overview (CME)
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a7ffb.html#wp1010500
Use the normal phone provisioning commands. In the "type" command, use the "CIPC" keyword to identify this phone as a Cisco IP Communicator.
Hope this helps!
Rob
Hi Chris,
From this doc;
From this doc;
Hope this helps!
Rob
Rob,
That is a helpful response. Although I had read the second document already this did nothing to confirm whether there was any requirement or not, however the first link is clear enough...
Thanks again,
/Chris
Chris,
I could not get my CIPC working with my CCME4.0.
If you have a solution by now, please help.
Joe
Joe,
Make sure you put "type CIPC" under the ephone that you created for the IP Communicator.
Shanky,
I have the command in, but it still does not work.
Joel
Please paste your relevant CME configs.
Shanky,
This is my config.
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:S00105000200.sbn
telephony-service
video
maximum bit-rate 128
no auto-reg-ephone
load 7960-7940 P0030702T023
load 7914 S00105000200
load 7941GE TERM41.7-0-3-0S
load 7961GE TERM41.7-0-3-0S
load 7971 TERM70.7-0-3-0S
max-ephones 52
max-dn 104
ip source-address 192.168.82.1 port 2000
max-redirect 20
no caller-id name-only
service phone videoCapability 1
system message Eng Engineering, Inc.
url services http://phone-xml.berbee.com/menu.xml
time-zone 12
time-format 24
voicemail 2050
mwi relay
max-conferences 16 gain -6
call-park system redirect
moh flash:music-on-hold.au
web admin system name xxxx secret 5 xxxxx
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9.T
secondary-dialtone 9
ephone 41
device-security-mode none
video
mac-address 0005.9A3C.7800
type CIPC
button 1:39
Joe
Hall of Fame Super Gold
Definitely there are no load commands to give, the CIPC is self-contained excpet that if you configure locales on the CCME that will just mess the font on the display.
What is that is not working ?
Is the phone to registering, unable ot place calls, or what ?
Guys,
I was using the CIPC through the VPN client. When I upgraded the CIPC from 2.0.1.1 to 2.0.2.0 and the VPN client from 4.8.02.9 to 4.8.02.10 it started working.
Joe
2667
