CIPC installation on ncomputing virtual enviroment
I am searching on google and cisco community about the installation and working of CIPC on ncomputing devices. As i have a doubt about installation and working of it on ncomputing.
Shahzad
2 ACCEPTED SOLUTIONS
 Cisco IP Communicator is not
  •  Cisco IP Communicator is not supported in VMWare, Citrix, Terminal Services, Remote Desktop or other thin client environments.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_4/CIPC_BK_C6B0FEBA_00_cisco-ip-communicator-864-release.html
java
if this helps, please rate
www.cisco.com/go/pdi
Jabber for Windows, read all
Jabber for Windows, read all the info in the RNs and config guides, available on cisco.com
Assuming you want RTP to end in the client, you need  VXME, otherwise, it's only deskphone control.
java
java
Thank you Jaime.So is there
Thank you Jaime.
So is there any option available so that we can use softphone in thin client enviroment?
java
172
